rollo disks for koxx?
is it possible for rollo disks to be fitted on koxx cranks? or is there any other options i could use to help keep my feet on the cranks?
cheers
No
Is it worth tryin grip tape?
No, Rollo Disks are specifically fitted to kh moment cranks.
Yes. Grip tape is a great helper for flatland, because it helps your feet stay on the cranks (less slippage).
but it´s not good for your shoes
I’m pretty sure that moments fit the cranks that is on stock devils. I and UniPsyco tried it some time ago.
No on the rollos, yes on grip tape. Grip taped 135s are amazing, I have 2 pairs.
Damn, I meant rollos, not moments. :stuck_out_tongue:
You wouldn’t want rollos on koxx trials cranks though because the cranks are straight so they would hit your ankles all the time.
Moments have a 10mm offset and the rollos are 10mm wide so it doesn’t stick out any more than the end of the pedal does.
I know, that is why we took them off again. :slight_smile:
ah cheers guys thanks for ur help!
ive now got grip tape on and its brilliant.
cheers
