rolling Triks
i have been unicycling for a little while. i can do static tricks like 180’s 90’s body variables and things like that, but when it comes to do them rolling (sif) i cant do it have you got any helpful tips :thinking:
i learnd the tricks till 360 like this you ride than hop a view times and then you do them.the next time you do it with a bit less hops and the next with a bit less hot until you do it rolling
thanks
Ill put that into consideration and try it after school tmz
Ride, stop, do the trick, ride.
Ride, slow down, do the trick, ride
Ride, slow a bit less down, do the trick, ride
And so on. But make sure you lift the uni from the ground when doing rolling tricks, otherwise it would just stay where it is, while you’re jumping forward.
That is the best advice I can give.
thanks
thanks for your help i took that into consideration and i tried it and after 30mins to 1hour i fanally got there!!
