Ok this is probably real stupid/real easy but i’m thick.
Can i use tryall rimtape on a kh05 rim? cause its quite wide. Should i just cut it a little or is rim tape not needed since there are no holes? or is it recomended but just doesnt matter about thickness as long as it covers the holes with the nipples?
yeah, i used it on my nimbus rim for a while and it was fine. just do 2 or 3 layers.
you only have to cover the holes so you should be able to cut itin half and use a fairly small amount of tape.
