rim and innertube problem
I bought a koxx one uni and those holes drilled in the rim allow the rim tape and innertube a space to push out though. Should I keep the tire at a certain pressure? Has anyone else with a koxx uni had a problem with this? Should I be worried about this or am I just being paranoid?
-Joe
1st: congrats. that sounds like a nice uni.
2nd: If it pushes through a slight amount that is normal. The rim strip should be thick enough to hold the tube without a problem at the tire’s suggested PSI. If it is pushing through a lot (not sure how that would happen) to the point where it looks like the tube may be in danger of herniating you may need t o reseat the tube and rim strip evenly as it may be stretched or bunched in a spot.
