I’ll be getting my first Muni in a couple of days from now (I’ll pick in
up at NewMilford bike shop, PA, Woohooo !). I am getting a little bit
anxious about riding with a ridged tire though. Last fall I put a
cheap-o mud tire on my cheap-o uni and I wasn’t able to ride it on
pavement. I even had a hard time on trails : It kept attracting me to
the right… I could ride quite easily with the stock tire though… Is
it likely that I will experience the same with the Gazz 24x2.6 ? I know
that tire issues have been discussed a couple of times and that it
seemed encouraging (at least with the Gazz…) but I would appreciate
some input on the transition between a 24x1.75 slick and the Gazz
24x2.6.
Have you tried riding the dirt tyre at a wide range of pressures? I wonder if it may be on the hard side- I’v found that tread patter effects are less with lower pressure. Of coarse, odd effects may occure at extreamly low pressure- the tyre may fold over and pitch you even on gental turns. By contrast, Lewis discovered that he likes his 3" Gazz hard- go figure.
I ride a gazz 24x2.6, and i have no prob roding on either pavement or dirt. The only thing i hate is how if i roll through some mud, it stays in the tread, and i cant get it out till i find a high powered hose. Any suggestions?
-David Kaplan
Yeah I’ve tried it. I tried different pressures (very low to very high). My
conclusion was that the tread on that cheap tire was not any good for
unicycling… I was just wondering if anyone had that experience and if the
Gazz was better than any other ridged tire for unicycling or if, on the
other hand, I might expect a hard transition even with the Gazz… (hope
not…).
Thanks,
Christ.
rhysling wrote:
> Christian,
> Let us know if the pressure makes any difference.
> Christopher
> rhysling - Last of the Mississippi Unicyclists
> “Si…like a low rider, man. I like eet when he jacks hees shocks, man.”
> -Ceramic Dog, Physicist
> rhysling’s Profile: http://www.unicyclist.com/profile/411
> View this thread: http://www.unicyclist.com/thread/17266
The problem you are having is probably due to the camber of the road. The
flatter (or more square) the profile of the tire, the greater this problem will
be. A tire with a round profile will have less of a problem. Some knobby tires
have a row of knobs down the center of the tire–these tires are especially bad
on camber.
I find my 26x2.7 Gazz is pretty good on pavement–though I try to avoid
it–unless I have too much air in it.
