I have an idea for a couple of drills that might make learning a lot quicker. This may have been covered somewhere else, but I’ve never seen it. Then again, I’ve never read a unicycling book; I’ve only used the fora at unicyclist.com.
I humbly await the opinions of more capable riders/teachers. If the ideas seem sound, I’ll write them up cleaner and post it in the tutorial section at unicyclist.com.
If anyone tries this, please let me know.
First: the reasoning
The biggest part of riding a unicycle, IMHO, is staying vertical. But most of the time learning is spent on trying to go forward.
The most basic motion we use is forward/backward pedaling and the second most used motion is twisting to change direction.
New unicyclists use exaggerated motions in these 2 areas and they don’t start to feel confident until they are able to make micro-adjustments without thinking about them. When the micro-adjustments are small enough, folks on the street will see a smooth-riding expert.
Second: the drills
Use a support that will allow at least a few feet of forward motion.
Get a feel for idling, pedaling backward and forward without going anywhere. Start with big motions then try to make the motions as small as possible.
After you’re comfortable with this motion (I have no idea how long this will take) then work on going forward in small steps - forward for a few inches, backward for a little less. Do this ratcheting motion until you’re able to go the length of the support without stumbling.
Next, while doing the same forward/backward ratcheting, twist the wheel under you. Do not try to change direction drastically, just a few degrees each way. Try not to keep the turns in sync with the pedaling. The twisting should be random.
When you can go the length of your support while doing these tiny twists and the ratcheting pedal motion, you should be able to go at least a short distance without support.
