Has anyone gotten into this. I’ve found any short stair case is pretty easy. But you don’t slide any of the rail, you tape the end go for about 6 inches, and hit the buttom. Hook me up if you’ve found a decent way to do it. Thanks for your time.
correct me if im wrong, but i belive they are talking about grinding UP the rail… Like starting at the bottom of the set, and grinding up, Right? I think ive seen somebody do this.
The first time i read it i thought he was riding up to the handrail backwards and doing a backwards rolling hop into a backwards grind down the rail. I think if its fakie, you go into it backwards but if you 180 into it then its a 180 handrail landing fakie (unless you 180 out of it too)
Riding forward, 180ing into sliding a handrail backwards. I think the record is a four set. It’s tricky stuff. If you want a clip, I have a clip of me sliding a four set. but yeah. That might help. Laters
