replacing spokes in a giraffe wheel
If the sprocket of a giraffe wheel is welded to the hub then how do you replace the spokes on the drive side of the wheel?
-mg
In short, you pray that you don’t break ANY of your spokes, as they are all equally impossible to replace on a welded sprocket set-up.
You could always grind the weld off, and then take it apart.
