Ok, I did it =p
I know that a lot of people have some troubles getting trials tires off the rim, specially with the Alex 32 Rim, so i made a short little guide, ill add drawn diagrams too, would use pictures but my webcam only takes somewhat good pic during a bright sunny day, and its night right now lol
Steps For Removing A Trials Tire.
1: With 3 Tire Removal tool thingys, set them under the tire with about an inch - inch in a half between each other.
2: Keep slight pressure on all three of the tools, i used one palm on two of them and one hand on the other, then pull the tire close to the rim with all three.
3: Once the tire is close to the rim and all tools are in place, use one tool to bring the tire up over the rim, while keep the other two in place with slight pressure.
4: Once the first section of the tire is over, you should still have 2 tools left under the tire, now push one those to bring about a 4-inch section of the tire over the rim.
5: You should now be able to take out all 3 of the the removers and have the tire still hanging over the edge, but it will still be tight to the rim.
6: take one of the remover tools, and with the little hook, the part you use to hook onto the spokes to keep you hand free, stick that in the middle of the section that is over the rim, pull to one side and the tire will easily slip over the rim, continue around the rim and it you’ll be done.
Using this method it took me about 2mins to get the tire off, and no damage to the tire, tube, or rim occurred.
Also, as your getting the tire back on, it can be pretty hard getting the last section on, so here is what you do.
1: Get a bowl of water, the temperature should be at room temp. and ad s enough soap into so when you put your fingers in it, you can feel that the water is soapy and lubricated.
2: take the water, and spread it across on the tire, inside and out, where it is stuck on the rim, and also add the water onto the rim.
3: Now try to put your tire on, the soapy water will make it so your tire will slip on gracefully, well, not too gracefully cause you will still need to add some force with your fingers, but it makes extremely easy.
Now with your new tire on, fill up and ride!
