Removing Koxx-One Cranks
I have a koxx one splined hub/crankset with an Alex DX32 rim. I wan’t to change the rim to a try-all but i can’t remove the cranks because they are taperd. Any ideas? :thinking:
Go to a local bike shop and get a tool for removing ISIS cranks. They’ll know exactly what you need and should even be able to show you how to use it. Or bring your unicycle in and they can show you how to use it on your uni. The tool is very similar to the tool used to remove standard square taper cranks, just a different size.
