Re: Unicycle Specs
on Fri, 23 Jun 1995, Troy Harding said:
> By the way, if I buy a standard 24" unicycle can I change the wheel size
> fairly easily. For example, could I swap the 24" wheel with a 20" or 26" wheel
> without much problem. (Sorry if this is a stupid question.)
“Easily” is a relative term. My fist uni was a 24" Pashley, I changed the rim to
fit a 26" one in. It fitted nicely, but to change it I needed to use a clutch
puller to remove the bearing/housing which were very tight.
Rgr
Roger.Davies@octacon.co.uk Cleveland UK
