klaasbil_remove_the_spamkiller_@xs4all.nl writes:
>The big wheel has more surface to catch side wind; moreover, on
>average that surface is farther away from the twisting axis, which
>increases the momentum. Assuming that the wheel rolls forward at
>appreciable speed, the friction of the tyre that resists twisting will
>not be very large (it would be significant if the rider did a
>standstill).
>Does anyone of the test riders of uni.5 so far have comparative
>observations to make on this point?
Having ridden nearly 60 often-windy miles on uni.5, I can say that as far
as wind goes, I am still not quite sure how uni.5 compares with a Coker.
This is in part because the crank sizes are different and there is a
quality to the uni.5 not found in Cokers which may cause it to ride slower
anyway (due, I believe, to the ‘slop’ or wobble felt when you pedal).
I can say that in stiff wind, neither unicycle is especially fun to ride.
But I think the uni.5 handles slower speeds better, so it probably handles
wind better for this reason alone.
David
Co-founder, Unatics of NY
1st Sunday / 3rd Saturday
@ Central Park Bandshell
1:30 start time after 11/1/01
