Re: Ultimate Wheel (vs. Seat Drag)
Hi Daniel,
Whereas I haven’t tried Seat Drag on a regular unicycle, my guess is
that you’re just right. The ultimate should be much easier, because the
pedals are closer to the plane of the wheel as you mentioned, and because
you can pretty much trap the wheel between your inner shins, and keep it
from tipping too far to one side or the other. Essentially, you became the
frame and bearings!
> Riding an ultimate wheel is easier then riding a regular unicycle in a
> seat drag right? I am assuming this because in the ultimate wheel the
> pedals are usually closer to the center plane, and therefore should be
> more stable. Please correct me if I’m wrong.
