Text item:
>You can order right- and left- threaded cotterless cranks from any Schwinn
>dealer. Other parts dealers (e.g. Island here in Minneapolis) list only
>cottered cranks, but may have a better selection of lengths. The unicycling
>FAQs also claim you can just remove the spider from a bicycle crank, but it
>seems messy to me!
>Does anyone out there have a good mail-order source for a wider selection of
>Uni parts?
Wider than what? The best selection in the world (though admittedly North
American-based) is most likely that of the Unicycle Factory. If anyone else
comes close I’m not aware of it.
John Foss reply to: unifoss@calweb.com
Text item: External Message Header
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: SunBear@MindSpring.com (Eric Johnson) Precedence: bulk Sender:
owner-unicycling@winternet.com Xref: paladin.american.edu
rec.sport.unicycling:4623 X-Newsreader: Anawave Gravity v2.00.753 X-Server-Date:
15 Nov 1997 17:17:00 GMT NNTP-Posting-Host: pool-207-205-139-218.chia.grid.net
References: <346cc15a.338261933@news.deltanet.com>
<346CEC27.1E384CD7@stratus.com> Message-ID:
<MPG.ed795011fa92deb989681@news.mindspring.com> Lines: 11 Organization: Townsend
Analytics Date: Sat, 15 Nov 1997 11:16:52 -0600 Subject: Re: Pedals Newsgroups:
rec.sport.unicycling From: SunBear@MindSpring.com (Eric Johnson) Path:
auvm!paladin.american.edu!news.ecn.uoknor.edu!news.wildstar.net!
newsfeed.direct.ca!cpk-news-hub1.bbnplanet.com!news.bbnplanet.com!mindspring!n
ews.mindspring.com!usenet To: UNICYCLING@winternet.com Received: from
AUVM.AMERICAN.EDU (NJE origin NETNEWS@AUVM) by AUVM.AMERICAN.EDU (LMail
V1.2a/1.8a) with BSMTP id 0750; Sat, 15 Nov 1997 16:28:16 -0500 Received: from
AUVM.AMERICAN.EDU by AUVM.AMERICAN.EDU (IBM VM SMTP V2R2) with BSMTP id 1062;
Sat, 15 Nov 97 17:08:57 EST Received: from auvm.american.edu(147.9.1.2) by
icicle.winternet.com via smap (V2 .0) id xma025270; Sat, 15 Nov 97 16:13:53
-0600 Received: (from adm@localhost) by icicle.winternet.com (8.8.8/8.8.8) id
QAA25292 for <UNICYCLING@WINTERNET.COM>; Sat, 15 Nov 1997 16:14:03 -0600 (CST)
X-Authentication-Warning: icicle.winternet.com: server set sender to
owner-unicy cling using -f Received: (from server@localhost) by
icicle.winternet.com (8.8.8/8.8.8) id QAA25401 for unicycling-outgoing; Sat, 15
Nov 1997 16:14:41 -0600 (CST) Received: from icicle.winternet.com
(icicle.winternet.com [198.174.169.13]) by thalia.fm.intel.com (8.8.6/8.8.5)
with ESMTP id OAA03447 for <JohnX_Foss@ccm.fm.intel.com>; Sat, 15 Nov 1997
14:45:49 -0800 (PST) Received: from thalia.fm.intel.com (thalia.fm.intel.com
[132.233.247.11]) by fmm ail.fm.intel.com (8.8.5/8.7.3) with ESMTP id OAA16559
for <JohnX_Foss@ccm.fm.int el.com>; Sat, 15 Nov 1997 14:44:56 -0800 (PST)
Return-Path: unicycling-owner@icicle.winternet.com
