Re[2]: How sharp is sharp?
Text item:
Wolfgang Stroessner wrote:
> Do you expect a level n candidate to show 1+2+…+n = n*(n+1)/2 different
> mounts (1 for level 1, 2 more for level 2 and so on). Or is it sufficient to
> know n mounts, i.e. you are allowed to use the n-1 mounts you used for level
> n-1 again for level n.
Mark Wiggins wrote:
>You can keep using the same mounts from previous levels - so only ten required
>for level 10. Phew.
Allow me to add something here as well. When you go out to pass the next level,
it is not necessary to repeat the previous levels, and only one new mount is
needed per level.
This raises the issue of tracking the mounts the rider has done for previous
levels. Is he or she cheating by repeating one? It is up to testers to keep
track of these things, which may lead to having the rider demonstrate all the
mounts he or she used for previous levels first.
55 mounts, without major variations, would be really interesting. How many
are known?
Stay on top, John Foss, the Uni-Cyclone
reply to: unifoss@calweb.com http://www.calweb.com/~unifoss/
(Intel does not necessarily agree with my opinions about unicycling
skill levels)
Text item: External Message Header
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: Mark Wiggins <M.Wiggins@ftel.co.uk> Precedence: bulk Sender:
owner-unicycling@winternet.com Content-Transfer-Encoding: 7bit
Content-Type: text/plain; charset=us-ascii References:
<9712081714.AA41574@operator.mathematik.hu-berlin.de> Subject: Re: How
sharp is sharp?
CC: Unicycling Mailing List <unicycling@winternet.com> To: Wolfgang Stroessner
<stroess@mathematik.hu-berlin.de> MIME-Version: 1.0 X-Mailer: Mozilla
3.0Gold (X11; I; SunOS 5.5.1 sun4u) From: Mark Wiggins
<M.Wiggins@ftel.co.uk> Date: Mon, 08 Dec 1997 17:31:35 +0000 Message-ID:
<348C2EF7.5A99@ftel.co.uk> Received: from midge.ftel.co.uk
(cWiP/8BnfebcZXWC1Id6bsnjX5ToxlTN@midge.ftel.co. uk [192.168.65.13]) by
europa.ftel.co.uk (8.8.7/8.8.7/Revision:1.32) with SMTP id RAA19667; Mon, 8
Dec 1997 17:31:36 GMT Received: from europa.ftel.co.uk(193.112.175.35) by
icicle.winternet.com via sma
p (V2.) id xma023491; Mon, 8 Dec 97 11:31:54 -0600 Received: (from
adm@localhost) by icicle.winternet.com (8.8.8/8.8.8) id LAA23516 for
<unicycling@winternet.com>; Mon, 8 Dec 1997 11:32:06 -0600 (CST)
X-Authentication-Warning: icicle.winternet.com: server set sender to
owner-unicy cling using -f Received: (from server@localhost) by
icicle.winternet.com (8.8.8/8.8.8) id LAA23632 for unicycling-outgoing;
Mon, 8 Dec 1997 11:32:42 -0600 (CST) Received: from icicle.winternet.com
(icicle.winternet.com [198.174.169.13]) by thalia.fm.intel.com
(8.8.6/8.8.5) with ESMTP id KAA06578 for <JohnX_Foss@ccm.fm.intel.com>;
Mon, 8 Dec 1997 10:00:52 -0800 (PST) Received: from thalia.fm.intel.com
(thalia.fm.intel.com [132.233.247.11]) by fmm ail.fm.intel.com
(8.8.5/8.7.3) with ESMTP id KAA11791 for <JohnX_Foss@ccm.fm.int el.com>;
Mon, 8 Dec 1997 10:00:07 -0800 (PST) Return-Path:
unicycling-owner@icicle.winternet.com
