Text item:
Mike wrote:
>Unfortunately the CYCLE computer has to be either in the seat or under it on
>the post so you have to be relatively flexible to read it while riding as long
>as you keep it low enough to see.
My original attachment of computers (for a girlfriend, and later for me) was on
the back of the seat post. We used a model that stored max. speed, average
speed, distance, etc. so you could look at it after.
Later I built a racing unicycle with the computer in the front of the seat.
This one you can just barely look at while riding, depending on your size.
But sometimes the buttons get pushed while you’re riding, and I don’t want to
say by what.
>Anyone seen any Wireless cycle computers yet you could were as a watch? Just
>a thought.
When wireless computers first came out, I was recommended by a knowledgeable guy
at a bike shop not to risk it. He said the signals were very weak on the things,
and they weren’t yet reliable. On a unicycle, if you have the computer on your
person (even in your pocket), it will be farther from the transmitter than it
would on a bicycle, so I saved the money at that time. The reliability of
wireless computers has probably gotten much better since then.
What I want is a computer with an altimeter in it. First I want to find out how
accurate they are, and then I might consider one for my MUni…
John Foss
Text item: External Message Header
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: Michael King <king@enel.ucalgary.ca> Precedence: bulk Sender:
owner-unicycling@winternet.com Xref: paladin.american.edu
rec.sport.unicycling:5267 X-Newsreader: MicroDot-II/AmigaOS 0.172
Content-Transfer-Encoding: 7bit Content-Type: text/plain; charset=us-ascii
Mime-Version: 1.0 NNTP-Posting-Host: mgking@ts1-port-29.acs.ucalgary.ca
References: <3518C8D8.1418CA90@orac.net.au> Message-ID:
<6fcjnb$mca@ds2.acs.ucalgary.ca> Lines: 15 Organization: Ethereal Design Date:
25 Mar 98 20:40:49 -0700 Subject: Re: Hotting Up a Unicycle! Newsgroups:
rec.sport.unicycling From: Michael King <king@enel.ucalgary.ca> Path:
auvm!paladin.american.edu!cpk-news-feed4.bbnplanet.com!
cpk-news-feed1.bbnplanet.com!cpk-news-hub1.bbnplanet.com!news.bbnplanet.com!ne
wsfeed.direct.ca!news.he.net!scanner.worldgate.com!rover.ucs.ualberta.ca!news.u
calgary.ca!news To: UNICYCLING@winternet.com Received: from AUVM.AMERICAN.EDU
(NJE origin NETNEWS@AUVM) by AUVM.AMERICAN.EDU (LMail V1.2a/1.8a) with BSMTP id
4409; Thu, 26 Mar 1998 05:13:37 -0500 Received: from AUVM.AMERICAN.EDU by
AUVM.AMERICAN.EDU (IBM VM SMTP V2R2) with BSMTP id 4436; Thu, 26 Mar 98
05:13:39 EST Received: from auvm.american.edu(147.9.1.2) by
icicle.winternet.com via smap (V2 .0) id xma002892; Thu, 26 Mar 98 04:18:29
-0600 Received: (from adm@localhost) by icicle.winternet.com (8.8.8/8.8.8) id
EAA02900 for <UNICYCLING@WINTERNET.COM>; Thu, 26 Mar 1998 04:18:43 -0600 (CST)
X-Authentication-Warning: icicle.winternet.com: server set sender to
owner-unicy cling using -f Received: (from server@localhost) by
icicle.winternet.com (8.8.8/8.8.8) id EAA02938 for unicycling-outgoing; Thu, 26
Mar 1998 04:19:17 -0600 (CST) Received: from icicle.winternet.com
(icicle.winternet.com [198.174.169.13]) by thalia.fm.intel.com (8.8.6/8.8.5)
with ESMTP id CAA08982 for <JohnX_Foss@ccm.fm.intel.com>; Thu, 26 Mar 1998
02:43:44 -0800 (PST) Received: from thalia.fm.intel.com (thalia.fm.intel.com
[132.233.247.11]) by fmm ail.fm.intel.com (8.8.5/8.7.3) with ESMTP id CAA25499
for <JohnX_Foss@ccm.fm.int el.com>; Thu, 26 Mar 1998 02:39:01 -0800 (PST)
Return-Path: unicycling-owner@icicle.winternet.com
