Text item:
Chris (and others) wrote:
>None of the holes in the new cranks are big enough to properly fit the hub of
>my current 24" OR the spare hub that I bought. As I don’t want the same problem
>that I had the first time round is there a way of enlarging the square, tapered
>holes in the cranks so that they will fit properly? By the way, file two
>ADJACENT sides. Just decide if you want your crank a bit (itty bitty bit)
>longer or shorter, and do them both the same.
We seem to be experiencing a rash of axles and cranks that don’t fit together.
I’ve never heard of this before. It’s possible that the manufacturer in Taiwan
has made a batch of hubs with spindles that are too large. Or perhaps there is a
new size for crank arms, which I doubt.
In case everybody didn’t know, when installing cotterless cranks for a unicycle,
you shoulc pound them on with a hammer before, and between, turns with a wrench
on the bolt. Don’t rely on the bolt to push the crank all the way down. This is
best done with a hard rubber mallet, and the wheel on it’s side with the pedals
off. Pound it real good.
I don’t own a rubber mallet, so I use a regular hammer and pound it carefully,
but still good & hard.
As I am currently using a 6" aluminum crank on my 26" “piece of Schwinn”, I’ve
gotten into the habit of giving the crank bolts a tighten (with the wrench)
before every ride. This has kept them nice and tight, and I’m sure they’ll out
last the axle. They outlasted the one before it…
John Foss http://www.calweb.com/~unifoss/
Text item: External Message Header
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: cjreeder@juno.com (Chris A Reeder) Precedence: bulk Sender:
owner-unicycling@winternet.com From: cjreeder@juno.com (Chris A Reeder)
X-Juno-Line-Breaks: 0-8,10-11 X-Mailer: Juno 1.49 References:
<199803240731.RAA03833@iccu5.ipswich.gil.com.au> Message-ID:
<19980324.101139.9694.1.cjreeder@juno.com> Subject: Re: cranks and axles -
problems Date: Tue, 24 Mar 1998 10:11:38 -0700
Cc: unicycling@winternet.com To: wvanwijk@gil.com.au Received: (from
cjreeder@juno.com) by m16.boston.juno.com (queuemail) id MbA02777; Tue, 24
Mar 1998 12:15:38 EST Received: from m16.boston.juno.com(205.231.101.192) by
icicle.winternet.com via smap (V2.0) id xma003568; Tue, 24 Mar 98 12:51:50
-0600 Received: (from adm@localhost) by icicle.winternet.com (8.8.8/8.8.8)
id MAA03662 for <unicycling@winternet.com>; Tue, 24 Mar 1998 12:52:05 -0600
(CST) X-Authentication-Warning: icicle.winternet.com: server set sender to
owner-unicy cling using -f Received: (from server@localhost) by
icicle.winternet.com (8.8.8/8.8.8) id MAA03716 for unicycling-outgoing; Tue,
24 Mar 1998 12:52:41 -0600 (CST) Received: from icicle.winternet.com
(icicle.winternet.com [198.174.169.13]) by thalia.fm.intel.com (8.8.6/8.8.5)
with ESMTP id MAA02145 for <JohnX_Foss@ccm.fm.intel.com>; Tue, 24 Mar 1998
12:06:12 -0800 (PST) Received: from thalia.fm.intel.com (thalia.fm.intel.com
[132.233.247.11]) by fmm ail.fm.intel.com (8.8.5/8.7.3) with ESMTP id
MAA19725 for <JohnX_Foss@ccm.fm.int el.com>; Tue, 24 Mar 1998 12:01:38 -0800
(PST) Return-Path: unicycling-owner@icicle.winternet.com
