Re[2]: crank length
Text item:
>What does a rider give up in going with a shorter crank arm? Stability?
>Anything? I’m interested in going a little faster on my 24", but not at the
>expense of control… Thoughts?
You give up leverage. You can’t stop as fast, accelerate as fast, or ride stuff
as steep or bumpy as you could with longer cranks. But unless you’re riding off
road (a lot), You should find the 5" much more efficient on a 24" wheel than 6".
John Foss http://www.calweb.com/~unifoss/
Text item: External Message Header
The following mail header is for administrative use and may be ignored unless
there are problems.
IF THERE ARE PROBLEMS SAVE THESE HEADERS.
Reply-To: allison@cwholesale.com (Hugh Allison) Precedence: bulk Sender:
owner-unicycling@winternet.com Subject: Re: crank length From:
allison@cwholesale.com (Hugh Allison) To: JohnX Foss
<JohnX_Foss@ccm.fm.intel.com>, unicycling@winternet.com Date: Mon, 16 Mar 1998
10:43:39 -0400 Content-Type: text/plain; charset=“us-ascii” Mime-Version: 1.0
Message-Id: <v01540b01b132ea91714e@[192.9.200.13]> Received: from
unknown(192.9.200.13) by cwholesale.com via smap (V1.3) id sma000687; Mon Mar 16
10:43:12 1998 X-Authentication-Warning: cwholesale.com: smap set sender to
<allison@cwholesale .com> using -f Received: (from smap@localhost) by
cwholesale.com (8.7.5/8.7.3) id KAA00689; Mon , 16 Mar 1998 10:43:29 -0500
Received: from news.cwholesale.com(38.228.190.2) by icicle.winternet.com via sma
p (V2.) id xma011547; Mon, 16 Mar 98 09:45:24 -0600 Received: (from
adm@localhost) by icicle.winternet.com (8.8.8/8.8.8) id JAA11697 for
<unicycling@winternet.com>; Mon, 16 Mar 1998 09:45:50 -0600 (CST)
Received: (from server@localhost) by icicle.winternet.com (8.8.8/8.8.8) id
JAA11839 for unicycling-outgoing; Mon, 16 Mar 1998 09:46:26 -0600 (CST)
Received: from icicle.winternet.com (icicle.winternet.com
[198.174.169.13]) by thalia.fm.intel.com (8.8.6/8.8.5) with ESMTP id
IAA21644 for <JohnX_Foss@ccm.fm.intel.com>; Mon, 16 Mar 1998 08:13:32
-0800 (PST) Received: from thalia.fm.intel.com (thalia.fm.intel.com
[132.233.247.11]) by fmm ail.fm.intel.com (8.8.5/8.7.3) with ESMTP id
IAA14219 for <JohnX_Foss@ccm.fm.int el.com>; Mon, 16 Mar 1998 08:09:12
-0800 (PST) Return-Path: unicycling-owner@icicle.winternet.com
