Rate my Picture?
I think that picture can be rated G. It can also be rated improperly sized.
E for Everyone sounds fair to me. No foul language or provocative themes or cartoon violence. Nicely done.
Im talking like a 1-10 rating…
Im gettin better at photoshop I think…
I dunno what to scale it one to ten. But its really cool!
I like it, maybe a 7 or 8…the double vision letters are a tad annoying imo.
So, anything else?
You need to be confident in your abilities without relying on outside opinions.
Very nice but…
  1. You look a little washed out in the midtones
  2. I don’t like the double lettered name thing at the top
  3. The shot itself is amazing
I am not a pro at editing but on a pro scale I might say 7, which is high
For an amateur I’d say 8 or 9
i’d give it a 9…if you had some huge air, it would be an 11 :astonished:
7-8
I love the picture. It’s simply fantastic. :slight_smile:
The one thing that I’m not all that keen on is the double letter font.
I wanted it to look washed out where I am. I added one greyscale midtones layer, and 2 overlaying high constrast layers on top of it.
Ill add some other photos of the trip next. including the original of the edited photo.
Get rid of all the white space
Change the text to just your name typed normally. The extra letters don’t look good and cause it to be confusing and hard to read. Keep the same colours and everything.
The picture is awesome. Don’t change anything else.
Better?
A couple fromthe trip…Tired of uploading.
nice few suggestions: center the text on the picture, maybe all caps, or lower case would give an even more balanced look imo
Edit: uniing looks fun btw
Much. I really like the new lettering. Also, I love the panoramic aspect ratio, but… are you sure you should be cutting off your arm? It’s almost like you are reaching up and grabbing the top of the picture for balance. I think showing your full body (arm included) against that awesome scenery and sky will give it more impact (nothing but sky above and rock below and you on one wheel). If you’ve cropped the sides, then maybe you can put some of that back and add some sky – that way you won’t mess up the cool aspect ratio (you’ll just get a little smaller, which might not look as good).
This is just my opinion, of course. I may look at it tomorrow and change my mind about what needs to be “fixed”. It looks great the way it is, actually. I just wonder (if it’s even possible) whether including your whole arm and hand would be an improvement.
Lastly, regarding oneisenough’s suggestions, I think the lettering looks fantastic the way it is. Mixed case looks best to me. I’m torn between whether it should be centered or left the way it is. I’m leaning toward leaving it the way it is. I don’t think it should be spaced out more so it goes all the way across.
