Qx series frame with KH Moment Hub
They’re not “supposed” to fit but it’s a matter of mm. Has anyone made them fit by grinding the bearing holders and the bearing holders on the frame?
Is that what u meant?
Yes but not on that particular frame, I forget which one (K-1 XTP?)
i had a quax frame on a moment hub. your all good
My QX frame wasn’t compatible with KH hub + Spirit cranks + disk brake because the bolts that hold the disk were rubbing the frame. Without the disk brake it would have worked.
