if the current paint is stable then rubbing it down to a matt finish will suffice. If it’s flaked/dmaged/rusty then cleaning the rim back to bare metal would be better. If you leave the old paint on, then a layer or two of undercoat and then some car body paint will work well. If you strip it bare you’ll need a layer of primer first. A clearcoat over the top will make the job last longer.
