Question since udc is down...bearing size
Anyone know the bearing type/size of bearings for the 24" torker dx? Do most LBS carry this type? Thanks!:slight_smile:
I think they are 42 OD, but I forget the ID. Oh, and I could be way off, or mixing up OD and ID.
What I DO know is that most LBSs don’t carry this bearing size. You have to get them from somewhere that specializes in bearings or probably torker.
I think that they are 40 OD. I could be wrong though.
Here is the info you need: Torker DX Bearings
It’s a non-standard size. The only place you can get that size is from Torker. The part number is in the above thread.
And in this thread, jagur has a solution that involves some minor surgery on the hub so it will fit a 40x19 bearing (a standard size used by Profile and others).
Jagur’s approach has the advantage that you’ll never need to go searching for a non-standard bearing size again when you need to replace the bearings.
