Re: Question on NUC races
I will try to answerDirk’s questions as far as standard skill is concerned.
The competitor decides his routine and fills his judging sheet. He makes up his
own routine (with some limitations), But once he turns it in, he must do the
skills on the exact order that he wrote down in the judging sheet, Each skill
has a value according to the difficulty. the sum of this values + 200 is his
potentially highest score. There are two ways that he might lose points.
1)Did not do the trick, did not complete it, or did it when he was not
supposed to do it.
2)Made mistakes. Minor mistakes (0.5 deduction) include waving of arms,
incorrect hand position, etc. A bad fall will be a 3.0 deduction.
The floor marks the distances. They are circles. The outside lines are 8 meters
in diameter which is the distance you must do the riding skills when you choose
the on a line option. When you choose to do the skill on a circle you must keep
outside the middle circle which has a 4 meters diameter and inside the 8 meters
circle. When doing figure 8 and when doing the lines you must go thru the small
circle in the center.
You must choose up to 18 skills that you must perform in 3 minutes. Only up to 6
of those skills can be mounts and/or transitions.
There are many tips on putting together a routine. Make sure it flows, practice
it often, memorize it. Check your stamina level. If you are not sure if you will
have time to finish it, make sure the skills that will be left out are not a
high proportion of your total value.
Freestyle is a show. But the judging is totally subjective. Other sports like
boxing, figure skating, gymnastics, etc., which has many more resources than
we do, have not been able to solve it. Standard skill has a more just &
objective scoring. I like both. I see freestyle like art, which is not meant
to be judged by people other than the artist. Standard is more like a
competitive sport. You really take away from his creativity, but structure it
so that you can measure it.
Hope that I was able to help you. You really ought to buy the booklet. Do try
to put up a standard skill routine for the NUC. You might have some
difficulties, but you will be able to put together a much better routine the
second time around.
Alberto Ruiz Ruizb@aol.com Member IUF Rules Committee
