Ok im trying to give as much info as possible so here goes…
I have a Qu-ax Trials (the one before the isis one) and
I’ve watched Evan’s crank de-nubbing tutorial and I know what to do and I have all the stuff but the problem is my crank bolt doesn’t allow it to happen. It looks like this… http://www.unicycle.com/shopping/shopexd.asp?id=926
And i’ve heard that you can replace the original bolt with this one… http://www.unicycle.com/shopping/shopexd.asp?id=927
so you can grind the nub off.
Will this work on my Cranks? Heres some ugly pictures lol…
I ground the nubs off the cranks on my 24" DX. The original bolts would not work for me either. I replaced them w/ those 2004 bolts and works fine now (now I actually preffer to ride w/ 170 mm Qu-Ax cranks and w/ the additional Q-factor, the nubs don’t bother me).
Make sure to put on a healthy amount of gear grease, so you can get the cranks off if you ever want to remove them again.
A crank puller no longer works for me. I have wedge a screw driver in there and rock it and the crank back and forth until I can pull off the crank. I’m sure doing this freequently will wear out the splines.
