well basically im asking that^^^^^^^^^^^^^^^^
Probably not as the hub would be too wide, but it is possible to bend frames outwards…But that isnt recommended
I am pretty sure not. In fact, I would say no, because the DX frame fits, if you pull it apart a little, but the DX bearing holders are smaller, and it rubs on the qu-ax hub. I would guess that the LX frame and bearing holders are even smaller.
Even if you could it woulnt be worth it unless you were going to change the rim and frame too.
