QU-AX 20" Freestyle/Profi
NEW QU-AX 20" Freestyle/Profi - $240.00AU
• Flat-crown frame with two-piece dropout
• Aluminium double-walled rim, silver 48 holes
• ISIS-hub
• “no slip” pedals with pins and inserts, round corners
• 20"x1.95" tyre, Kenda, up to 62 PSI; dual compound: soft on the side for perfect grip in curves, hard in the middle for less use
• Light aluminium one-bolt clamp
• 350mm seat post, diamond knurled (prevents twisting) Ø 25.4mm, aluminium, silver
• Light saddle, black with handle
• 4.6 kg
