Firstly, it’s probably better to anti-seize the allen key rather than locktite it. But thazt’s unimportant. Whatever you do, DON’T TAKE APART THE HUB AND AXLE! That’s completely unneccessary. It’s not the keyway because the key would only be one click or movement.
From the description, I will bet that the clicking is completely superficial. What frame do you ride? Does it have the same kind of bearing holders as the united main-cap and Yuni or Nimbus 2? Does the wheel seem to stop spining faster than it seems it should?
If so, you probably don’t have enough spacers between the hub and bearing and the hub and crank. This is causing the hub to rub against the bearing holders, and mkaing a clicking sound in the proccess. This was the case on my Onza, and it rubbed on my profiles, except it never clicked because the rubbing was too hard. I think most profiles come with three spacers per side. Remove your cranks (described below), and then pull off your bearings and anything else on the axle and remember the order that they went on (except the hub, of course). You should have six little rings of metal probably coated in grease, two cranks, a hub/axle, two bearings, two allen bolts, and two little aluminum washers that go with the allen bolts.
Now, take the hub and on one side, rather than having only 1 little ring of metal (spacer) between the bearing and the hub, try having two. Once you have two spacers on each side of the hub, put on the bearings. Then, put on the last two spacers and the cranks. My cranks have the unground nub and still clear my Yuni frame with just one spacer, so you should be fine.
That’s my diagnosis. Also, when you reeassemble, use lots of anti-seixe on the splines after cleaning them.
As for removing the cranks, go to your local downhill bike shop. They should have an abundance of profile crank tools. As for one, as one should’ve come with your profiles. Most likely the shop will be obliged to give you one. Hold the crank near the axle so it’s the only thing touching the wheel. Now, with the tool completely threaded in, begin tapping on it with a small hammer. Eventually the wheel should drop out of the crank. You should hold the wheel over a soft surface to protect it if it falls. An old scrap pillow is ideal. Now do the same on the other side. When putting the cranks back on, put both on before tightening ethier all the way. This keeps the hub from moving on the keyway.
