Would like some advise from seasoned riders who have suggestions on how to properly protect the fellas from going numb on a long ride.
Have I failed to properly adjust my unicycle?
This is not a joking matter…please help!!
Thanks
Thanks
Cornstarch helps for chafing. I know it’s lame, but powder your “buddies” up with some cornstarch and you should be chafe free to an extent. Wearing bikeshorts helps ALOT, too. Theyre relatively inexpensive, and wil save you from saddle soreness and will keep your junk out of the way. Wear them under your normal shorts if you are shy. But the ladies like it if you just wear them by themselves.
If you geve more info, you could get more help, and this should be in RSU.
biek shorts, and putting as much weight on the handle as you can. think about getting a gb4 handle or simialr for really long outings. what distance and on what uni and seat? more info would get better suggestions.
that, and an airseat would be good too.
I had the same problem. Here was my solution:
No more problems whatsoever.
Practice. Oh and don’t sit on your balls. All the other things are unimportant compared to practice.
Work up to long rides. If you live less than 5 miles from work, ride to work on your uni as much as you can. If you ride 3 or 4 miles a few times a week for a few weeks, you’ll soon have no problems with 30 mile rides. If you ride 5 miles a day for a couple of months, you’ll have few problems with 50 mile rides. That’s assuming you’ve got a biggish wheel, for a smaller wheel half those distances and it’ll still make sense.
Joe
