Here are some pics of my custom muni. I used two 1/2" tubes for each side of the forks. The crown and the seat tube are 1". The bearing caps are CNCed and everything is made from 4130 chromoly. The thing in one of the pics that looks like a hub is a dummy hub I used to weld the frame together. The handle and seat post are also made of 4130. The cranks are Race Face and consist of a right mountain bike and a left tandem crank, both are 170mm. If you look closely you can see that I offset the tubes where they meet the bearing caps and I also tapered them in to give extra clearance for the Gazz.
I did not set out to make the ultimate muni. This is just my rendition of a very open design area. This was the cheapest and easiest and also the quickest since I am extremely busy at work. When I get out more and get better I will post some pics of me on it.
Wayne.
