pics and plans of diy mini g
well this thread is for all those interested in maybe making their own mini g it will have a few pics and stuf for you all to see, enjoy and use.
NOTE: the plans will not be exactly actual size so only use as a guide.
another
and gues wat another
thanx for all your input so now i have something for u
here is a step by step instruction how to manual thing!
1: go out there and find yourself all the stuff you cant make like wheel, cranks, pedals, chain, sprokets, tyre etc because these are what you base your plan on to make sure it will work (no good planing before you know what you are using). i would have liked to use a wheel off one of those push things used for transporting fridges and stuf but putting bearings, axel and stuff on would b too hard so i used the smallest bike wheel i could find.
2: Find, figure out or get the material (metal) you plan on using for the project.
3: measure everything and i mean everything u will be suprised at how many things you need to know the measurement of when drawing your plan.
4: Draw up your plan with all the measurements of the components (parts) you have taken earlier. i found it best to make the plan actual size because you can sceck everything is right on it while building. place the crank and etc, as close to the wheel as your frame will allow ( looks cooler and ends up smaller this way).
5: Get to it and get everything cut to the exact size and shape and ready to be put togeather. cut the crank housing and grind it smooth so it can be welded into the frame later.
6: Build it, weld everything togeather grinding off sharp edges etc, and measuring it throughout the process to make sure it is right. Remember to weld the freewheel to the hub so u dont have any unpleasent problems later on.
7: Assemble the entire thing to make sure it all works as desired.
8: Go and buy some paint and sand the whole thing, prime it with primer, and spray it with what ever colour of paint you want. follow directions on the can for best results!
9: re assemble.
10: The most important part ride it and enjoy your new creation.
hope this helps and as for the plans it wont let me attach them so sorry but if you cant make one with these pics and instructions well i dont think you deserve to ride unicycles anyway happy mini g building!
A normal bike hub is Freewheel, what did u do to make it work like a Unihub, weld?
Btw: thats a realy nice bike u got there.
yeah weld it to the hub so it all moves as one but make sure tha axel will still turn freely
