when i have them activated, the script wont run, when i comment them out,
it runs fine, with the exception of not sorting out the files by the
extensions.
$path is assigned the dir of the files im working with, and $newFile is
the name of the file, so it should be looking like pathinfo(“path/file”);
“Jon Caruana” <jcaruana@home.com> wrote in message news:9rcfb1$rf7$1@www.t-shirtcountdown.com… > > i wrote a php script, has these two lines > > > > $preFileType = pathinfo("$path/$newFile"); echo > > $preFileType[“extension”]. "
"; > … > > What does this display if you replace those lines with it? > > echo "path=$path<br>
"; flush(); echo "newFile=$newFile<br>
"; > flush(); $preFileType = pathinfo("$path/$newFile"); > print_r($preFileType); flush(); echo $preFileType[“extension”]. "
"; > > > – > Jon Caruana jcaruana@home.com
