I had just finished a hell hard MUni ride in the heat, and i felt this odd clikking sensation in my foot, it turned out the pedal was coming undone, i quickly carried it to a friends house, who screwed it back in again, but i can still feel a clikking sensation, the weird thing being the pedal isnt unscrewing, it is also making a kind of “CRITCH” noise when i ride, but not when i spin it, also, it doesnt spin as much as the other one.
What is this?
i hope it is not bad
sounds like it could be either the bearings or the pedals thread, but that is only a guess from wat u have sed!!
sounds like what happend when my thred ripped in my uni
i felt a clicking aswell might be that
i have this exact problem after riding my kh for a few weeks. no matter how hard i tightened the bolt to the crank it always wiggled and made noises. turns out is was the berring and it was pretty easy to fix. all i had to do was pop this plastic cap off the end of the pedel opposite the bolt that you screw into the crank, inside there are a bunch of nuts that loosen or tighten the berring. after a bit of experimentation i had the problem fix. good luck:)
-paul
Re: Phantom Pedal
> as the other one.
Are you sure it’s still the pedal making the noise and causing the
clicking sensation? Check that the crank didn’t work loose while the
pedal was loose.
Danny Colyer <URL:http://www.colyer.plus.com/danny/>
Subscribe to PlusNet <URL:http://www.colyer.plus.com/referral/>
“He who dares not offend cannot be honest.” - Thomas Paine
