I need to get a subsring of the name of a file opened through @argv. I
need the first letter of the name of the file, but it needs to be able to
come from any directory.
I need just the file name part, not the directory information.
Its been a while since I’ve been around Perl syntax (Go PHP!), but… I’m
assuming that @sources includes the full directory, for example,
/foo/bar/ho/ho/what.conf. You could split the text between the /'s (into
$source[]), and then use $var = substr($source[-1],0,1);
“Mark Lyon” <mark@marklyon.org> wrote in message news:3B0F078B.3C29D49A@marklyon.org… > I need to get a subsring of the name of a file opened through @argv. I > need the first letter of the name of the file, but it needs to be able > to come from any directory. > > I need just the file name part, not the directory information. > > Can anyone help? > > > @sources = @ARGV; # save what was passed > > foreach $source (@sources) { > > $the_variable_i_want = subsr($source, 0, 1); > > }
Yeah. wound up doing that. had to think for a few mins. Mac Perl has some
really strange quirks.
“Sean S.” wrote:
> Its been a while since I’ve been around Perl syntax (Go PHP!), but… > I’m assuming that @sources includes the full directory, for example, > /foo/bar/ho/ho/what.conf. You could split the text between the /'s (into > $source[]), and then use $var = substr($source[-1],0,1); > > – > Sean S. <?$s=“moc.seiticoeg@osomynus”;$s=ereg_replace( > “osom”,“noom”,$s);$s=strrev($s);echo"mailto:$s";?> Hex(RGB) -> > http://thedoh.dyndns.org/hexrgb/index.php > > “Mark Lyon” <mark@marklyon.org> wrote in message > news:3B0F078B.3C29D49A@marklyon.org… > > I need to get a subsring of the name of a file opened through @argv. I > > need the first letter of the name of the file, but it needs to be able > > to come from any directory. > > > > I need just the file name part, not the directory information. > > > > Can anyone help? > > > > > > @sources = @ARGV; # save what was passed > > > > foreach $source (@sources) { > > > > $the_variable_i_want = subsr($source, 0, 1); > > > > }
