penny farthing wheelie...
Hmmm, if unicyclists are considered extreme then our forefathers (and
foremothers) must have been a bunch of Kris Holms. I am referring to the
story that goes like this… “Unicycles developed from people doing endos
on their penny farthings”.
I recently tried this trick on my penny farthing and I still get scared
thinking about it now. I was performing at a Goodwill Games event when
someone in the crowd called out “do a wheelie”.
I obliged him by popping up the back wheel and riding for about 1 1/2
revolutions on the front wheel. As the wheel is 42" across, this is quite
a distance. It is very scary being so high up with handlebars just above
your knees preventing any bail out should you overbalance forwards.
Luckily I pulled it off and vowed not to do it again until the next time.
Wayne van Wijk.
I saw John Foss do this as part of his unicycle show at the Davis
Cyclebration. He explained, over a public address system through a
microphone clipped to his shirt, how unicycling got started into as he did
the trick. I’m not sure if he had ever done the trick before, I don’t
think he had. I know I watched him trying to figure out how to do it
before the show. I can’t remember exactly what he said after he finished
the trick (which was also amplified), but the implication was he didn’t
want to do it again.
John Hooten
> story that goes like this… "Unicycles developed from people doing
> endos on their penny farthings".
> quite a distance. It is very scary being so high up with handlebars just
> above your knees preventing any bail out should you overbalance
> forwards. Luckily I pulled it off and vowed not to do it again until the
> next time.
> Wayne van Wijk.
> did the trick. I’m not sure if he had ever done the trick before, I
> don’t think he had. I know I watched him trying to figure out how to do
> it before the show. I can’t remember exactly what he said after he
> finished the trick (which was also amplified), but the implication was
> he didn’t want to do it again.
But I do!
I learned this trick on a little bitty penny-farthing. This was a 1960’s
novelty bicycle with a 28" front wheel and 16" back wheel. In fact you can
see a picture of a young John Jenack riding it if you have a copy of the
Bicycle Builders’ Bible by Jack Wiley.
Anyway, that bike was easy to learn on the front wheel because it’s
smaller and lighter. With that knowledge, I tried doing it on Tim Bustos’
heavy Ridable Replicas bike in my Cyclebration show. I practiced for a few
minutes before the show. I also did the same last year, but with no
practice in between.
On the bigger bike (I think his is about 48"), you are indeed higher up,
the back end of the bike is quite a bit heavier, and the back end tends to
fall to one side or the other. It’s easy enough to keep from going over
the front, but putting more power into the pedals. But yes it is scary…
John Foss, the Uni-Cyclone jfoss@unicycling.com www.unicycling.com
If you’re a terrorist, God is not on your side.
P.S. The same goes for Allah.
As in If you’re Allah, God is not on your side?
Klaas
“To trigger/fool/saturate/overload Echelon, the following has been
picked automagically from a database:” “missile, Usama bin Laden,
Mohammar Khadafi”
