pedals and cranks coming undone
> Any simple solutions for preventing pedals and cranks coming undone?? I was
> thinking about just gluing them together with a tiny bit of glue .
> . .is this dumb?
> any help appreciated
Make sure that the crank arms are on the correct sides. Somewhere near the end
of the arms you should see an L or an R. The threads go in opposite directions
to help keep the pedals in firmly.
Otherwise, you can get Loctite or something similar to glue the threads.
Beirne
Beirne “Bern” Konarski | Unicycling Home Page: beirne@ald.net |
http://www.unicycling.org “Untouched by Scandal” | Unicycling Society of
America:
| http://www.unicycling.org/usa/
. .is this dumb?
Re: pedals and cranks coming undone
>Subject: Re: pedals and cranks coming undone Sent: 13/10/97 10:03 pm Received:
>14/10/97 7:56 am From: Roger Davies, Roger.Davies@octacon.co.uk To:
>unicycling@winternet.com
>> > . .is this dumb?
>end
>> directions to help keep the pedals in firmly.
>If the cranks have been coming off for a long time, this is one answer (you
>should use a good epoxy resin - 24 hour setting type, not the 5 min junk), the
>other answer is to insert a shim on the damaged hub (they damage very quickly
>if ridden when loose), beer cans make great shims - but don’t slice your hand
>open when making them as I did last time I made one. If your hub and crank are
>in good condition use a light oil (or washing up liquid and water) on the taper
>when assembling. This allows the crank to slide up the taper easier and hence
>get a better fit. A light oil is better than grease as it takes up less volume
>and evaperates with time. Using a lubricant when putting aluminium cranks on is
>especially needed.
>Roger
> Roger.Davies@Octacon.co.uk
> Stockton
> North East England
um, in dire need I had mine welded! Five years later its still in use.
Martin
Martin Hungerford
> > . .is this dumb?
other answer is to insert a shim on the damaged hub (they damage very quickly if
ridden when loose), beer cans make great shims - but don’t slice your hand open
when making them as I did last time I made one. If your hub and crank are in
especially needed.
Roger
                                Stockton
                           North East England
end
>to help keep the pedals in firmly. Otherwise, you can get Loctite or something
Call me stupid, but I used that ‘kneadable metal’ stuff…mix the bits together
and it sets like steel - just squish that onto the thread and put the crank back
on - works like a dream! …just dont expect it to come off thats all…
Michael.
