I hadn’t checked my pedals on the way out the door. I assume they had loosened when idling but I was a mile into my ride so who knows. There could be thread wear I suppose but they haven’t come loose before and the wear isn’t visibly obvious.
I install them with an open ended wrench. Tighten them snug and then give the wrench a few good taps with a rubber mallet. The method has served well in the past. I grease the threads a little too but don’t see that as a problem - maybe it is? In summary - I just don’t know.
The stamps on the cranks and pedal spindles are usually good reference points. +1
I don’t see how this is possible without having the pedals inside the wheel. A crossthreading pedal will not thread all the way in. You have to take the crank off to get the wrong pedal into the opposite hole which will always look wrong when the unicycle is assembled.
It could be a case of having your seat the wrong way around too- the pedals and cranks can be aligned with the frame and a simple mistake of putting the seat backwards can allow your pedals to unwind. Unless there is a phantom pedal unwinder lurking there shouldn’t be any mysteries about why pedals come loose- they self tighten when installed correctly.
To add another tangent to this strange thread I will add that running home 1 mile kinda kicked my ass. My legs are still sore in places that never get worked. Guess I’ll have to run once in a while
This is the incomplete belief system of many people. Pedals self-tighten when installed correctly and when they have healthy bearings. If pedals had bushings instead of bearings they would naturally loosen in the configuration in which they are installed. The balls in ball bearings rotate in a direction opposite to the motion of their contact surfaces. If the balls don’t roll freely, the good ball bearings turn into bad bushings and the pedals unscrew.
I think that this bad ball bearing thing was causing my problems because my pedal does not seem to spin very freely.
So i guess that answers my question about if i should get new pedals. Thanks
Hi, just caught this thread. I had this happen to me on my recumbent bicycle – riding along, then the left pedal just popped off. Definitely not a problem of having the cranks switched there. Soon after that I replaced the pedals, because they were getting really rough and had play in the bearings. I’d never connected the two issues before, but it sure sounds like Harper’s theory explains what happened to me.
