Pedal Clim or Crank Climb?
Right now I can Crank climb and today I have landed a Pedal Climb…Which one do you think I should Master better?
They are usually called pedal grabs, as in ‘pedal grabbing to rubber’. (pedal grab, then up to land on the rubber of the tire)
Pedals are harder to learn and get good at, but they are much more usefull when you start using them more.
Forrest covered it pretty much.
unless you mean climbing an object using pedal grabs, which I have only done once, and its hard to find rock ledges or any ledge with the right holds for such a maneuver.
