So the motion is: left foot on tyre (if you’re that way round), right on
the pedal, left on the pedal, seat in. Imagine this all happening, and
you just being propelled upwards (straight back, uni vertical(ish)).
It’s important to look forward and not let the uni lean forward.
Imagine how the weight is transferred. The weight transfers need to be
more or less complete, not sharing. left right backside.
Good luck!
Cheers, Paul.
That sounds cool and basically how I tried to mount a giraffe unicycle. However,
I tried it on a DM 5-8 foot set on the 5 foot mode. I figure that if you were
look at a 8 foot, the peddles are a long long long way away from the tire. This
is just my theory. Can you still mount in the same way?
Scott
| ill communication
Scott HOne | the phone is ringing …oh my god!
| #7
Chin up little juggler you’ll see that rainbow again.
shone@neumann.une.edu.au |
http://fermat.une.edu.au:70/0h/homes/ug2/shone/.www/homepage.html
