Pashley bolt size
I just got my new Pashley MUni in the mail, but to my dismay I couldn’t find any allen wrenches (those 6-sided things) around my house that fit into the bolt to tighten the seat clamp. Does anybody know what size this is? Is it metric? I was anxious to ride my new MUni, so I used an allen wrench that was just slightly too small. It worked for right now, but I want to find the right size so I don’t end up stripping the head on the bolt.
Thanks! :slight_smile:
-Josh
The parc tool allen wrench (which comes with the small parc toolset box)
works fine, unfortunately I don’t have the exact size in mind.
BTW is there another clamp that works on the pashley seatpost ? My seat
keep turning when I’m hopping and I don’t want to overtight it.
Oli-
-----Original Message----- From: Zahnpasteus
[mailto:forum.member@unicyclist.com] Sent: Friday, June 29, 2001 8:35 AM
To: unicycling@winternet.com Subject: Pashley bolt size
on the bolt.
Thanks! :slight_smile: -Josh
Posted via the Unicyclist Community - http://unicyclist.com/forums
When I first got my Pashley, I had exactly the same problem. Actually, I
had the right size Allen wrench, but it was striped from all the use on my
old unicycle. Anyway, I the size you need is 5mm.
Ben Plotkin-Swing “Zahnpasteus” <forum.member@unicyclist.com> wrote in
message news:9hhslt$gdf$1@laurel.tc.umn.edu
> on the bolt.
Thanks for the info. Yeah, I have that same problem with the seat turning when I hop. Will it hurt it if I tighten it too much?
-----Original Message----- From: Olivier Paugam
> seatpost ? My seat keep turning when I’m hopping and I don’t
It seems solid, but I’m not taking any chance (and I got the miyata post
adapters I don’t want to screw up)
And I prefer to adapt it pretty often since I prefer a lower seat height
during trials and higher during a muni ride
[mailto:forum.member@unicyclist.com] Sent: Friday, June 29, 2001 12:05 PM
To: unicycling@winternet.com Subject: Re: Pashley bolt size
