Pashley 26-inch Power MUni Wheelset Ugrade
Which is the distance between the bearings on this wheel ?
Re: Pashley 26-inch Power MUni Wheelset Ugrade
Cedric,
From experience these bearing last and last! I have only ever replaced 2
pairs and they were over 15 years old! The reason it that they are held so
well within the bearing holders giving no pressure points.
Roger
The UK’s Unicycle Source
----- Original Message -----
From: “Cédric Monneron” <cedric.monneron@xemics.com>
Newsgroups: rec.sport.unicycling
To: <rsu@unicycling.org>
Sent: Monday, December 02, 2002 8:00 AM
Subject: Pashley 26-inch Power MUni Wheelset Ugrade
> rec.sport.unicycling mailing list -
www.unicycling.org/mailman/listinfo/rsu
Sorry but …i have some problem with my english !
I don’t want to know the age of the bearings but the length between
the bearing of left and that of right-hand side !
Roger Davies wrote:
> Cedric,
> Roger
> __________________________
> http://www.unicycle.uk.com
> ___________________________________________________________________________
Sorry, your English was ok, it was my reading that was bad.
It is a standard Susue hub so should be 76mm between the inside of the
bearings I believe.
Roger
Sent: Monday, December 02, 2002 11:13 AM
Subject: Re: Pashley 26-inch Power MUni Wheelset Ugrade
> Roger Davies wrote:
> > Cedric,
2
so
> > Roger
> >[color=darkred]
> >[/color]
___________________________________________________________________________[color=darkred]
>[/color]
I want to find a wheel with 86mm between the inside of the
bearings. The bearings width is 12mm.
I don’t know the type of my MUNI…
If you can help me …
> bearings I believe.
> Roger
> > Roger Davies wrote:[color=darkred]
> > > Cedric,
> 2
> so
> > > Roger
> >[/color]
