I am in the prosess of painting my Summit frame White/Black Checker board. Do oyu guys have any tips on masking? And thing to match out for or things not to do? I still havnt figured out a good way to mask for Checkers. Here is what iv done so far…I wire brushed as much as i could, then i used paint Stripper and a Dremel for the rest. Right now its sure white, with about 3 coats of white. Here are some pics…
u could just cut out a perfect square on paper and then stick it to tape and cut around it
then u could keep making more of the tape squares and put them all down
other wise i hav no suggestions
we’ve done masking, but not that precise. how big do you want the squares? if you could live with less precision (which I think would be mega cool) just do it with masking tape. If you want big squares, find the width of masking tape and make a square that wide.
have other people done it? I haven’t seen any designs on frames that intricate before…I’m with Fuego though, you could use masking tape or something, I think that would work.
PS duuude, your frame has the triangle shaped foot holders too!! mine doesn’t, but my friends does, and I think that’s pretty much the weirdest thing ever.
the best way to do it, is to completly cover the frame in masking tape, tehn with a straight edge and an exacto knife, cut a grid into the tape. Then peel away the unwanted squares. This will be much more precise than trying to stick on the squares.
I’ve had better results using electrical tape personally masking tape tears really easy and is easy to get unwanted folds in the tape on corners. ThisGuy’s method is the way to go just make sure that white paint is fully dry before you think about puting any tape on it. You can use alcohol normally to remove any gunk the tape leaves behind. Just make sure you dont push too hard with a blade you only want to cut through the one layer of tape and not the paint.
