Orange Nimbus 24-inch MUni Cycle with ISIS hub
I recently purchased this MUni new from Unicycle.Com (Item # UNNI24MIO-1331). I only got a chance to ride this unicycle once. I rode on a grass field so this MUni is very close to mint condition. I posted the close ups so you could see the great powder coated finish.
Price: $275 plus freight. PayPal preferred. No trades.
I will ship in the original packaging by UPS insured from zip code 77079. I will charge you actual freight. You can use the UPS web site to estimate your freight cost. The shipping weight is 26#.
I am sorry my first post is in the Trading Post. I have been lurking for a while.
Send me a PM with your offer to buy and your email address. I will contact first come; first serve. Thanks for checking out my post.
Description:
(NEW) Nimbus Muni Frame
Steel, flat-top style frame with Magura brake mounts
Frame Finish - powder coated
Color- Orange
42mm Machined Bearing Housing (22 X 42 X 12)
ISIS hub/axle/crank arms:
ISIS CrMo Steel Hub
Nimbus Venture ISIS alloy cranks- black
Crank Arm Length - 150mm
Saddle
Nimbus Gel Orange
S.P. Diameter - 25.4
Nimbus Alloy Seat Post Size: 25.4 X 350mm
Black Nimbus Double Bolt Clamp (25.4)
Tire/Rim
Tire 24 X 3.0 (Duro Wildlife)
Tire PSI - 30-50
Rim- 24-inch, 36 Spoke, Double Walled, Aluminum Alloy,
Cycle Weight- 17#
