Don’t believe the weights, these unis are essentially the same, so if there is a weight difference it’ll be in the tire, 3" Duro on the Oracle and 2.5" Kenda on the QuAx.
The QuAx has 48spokes, so heavier and an overkill, so some more weight and complxity, it has the post mount which is a little nicer for wheel removal but not a big deal; how often do you remove your wheel and when you do, don’t you also remove the bearing cap?
More than likely, if the tires were the same, the QuAx would be heavier due to the wheel build.
Quality is probably about the same.
Resale is probably better on the Oracle…
The Oracle brake is pretty solid, Bengal, may even be upgraded to Magura in future models. The QuAx uses a low end Shimano which has caused me some probelms with C Clip failure on the plunger.
If you like the rim color, the Nimbus is sporting a super strong Nimbus 2 rim, custom made for Nimbus, works great for tubeless. I don’t know the QuAx rim, probably in house designed or rebadged from another maker.
Frames are essentially the same.
Seats, well, I don’t like he Nimbus so I always upgrade to a KH, so that would be an extra expense if you do the same.
Cranks, those new QuAx cranks are sweet, Venture II’s are fine, not my favs, I run KH.
Both unis are ISIS.
Seat posts are both fixed, so the same.
Pedals are stock, buy aftermarket later on…
