Hi everybody,
it is spring cleaning time (first batch).
Have to go:
Shimano Deore M535 front disk set (with 160mm disk – see below). It is in perfect condition, looks like never used. Already bled and short enough to be used as-is. It is the combined lever-shifter. I think some parts can be taken apart according to the manufacturer documentation. Can also be replaced by a lever only (BL-M535). Weight as-is: 496g
Avid Elixir1 rear disk set (with 160mm disk – see below). It is in perfect condition, lever installed. Already bled. But line will definitely be too long for unicycling except for a giraffe with handlebar :D:D Weight as-is: 292g
160mm Avid rotors. The one with round holes weights 92g and the other one weights 100g.
Origin8 Devist8or 26x4.0 tire. Pics and details in this other thread.
I tend to favor trades, so here is the parts I am specifically looking for:
- disk ready cranks (Spirits or else)
or 100mm disk ready hub - 24inches frame with magura brake mounts
- dual hole cranks (110mm & whatever else)
As usual, if you have other parts or $$ make your offer
Deore_ST-M535_parts.pdf (355 KB)
