onzas
does anyone with the onza 20" have a problem with the cranks. mine make annoying noises from the spokes. And the cranks have had movement in them since i brought it
Re: onzas
There have been several instances of noises from the cranks and even some
movement. It has been solved in every case, as far as I can tell, by just
tightening the cranks up on the central bolt. I also mean really
tightening! I use an 8" alan key and really put some weight on it. This
should solve your problem.
The only on going problem we have is with one unicycle that the bolt kept on
coming loose. Locktight solved that without any problem.
Roger
----- Original Message -----
From: “tomuni” <tomuni.iwthz@timelimit.unicyclist.com>
Newsgroups: rec.sport.unicycling
To: <rsu@unicycling.org>
Sent: Saturday, February 15, 2003 8:45 PM
Subject: onzas
> tomuni
> tomuni’s Profile: http://www.unicyclist.com/profile/3550
> View this thread: http://www.unicyclist.com/thread/23517
> rec.sport.unicycling mailing list -
www.unicycling.org/mailman/listinfo/rsu
