Yo, just want some input from anyone that owns an onza trials.
Can it take drops?
Is the seat all right?
Is it worth the money and will it hold up?
Thanks
-Keaton Miller
Can it take drops?
Thanks
-Keaton Miller
This post should really be in R.S.U you will get waay more replies that way.
Personally I don´t own an Onza, but I can tell you that it will take drops.
The seat is really good.
And if it´s wort the money is up to you, but I don´t know about the hold up part. Better leave that to someone else.
Re: Onza
the real question is can you take drops? the cranks will hold up fine for drops up to 7 or 8 feet as long as you can land them well. some people have bent the cranks to hell from 4 or 5 foot drops because they did not land them well.
it comes with an older kh style seat. it is good, but the newer kh seats are much much better.
if you treat it right it will hold up fine.
and according to a few thread watch out for the pins in the pedals… they seem to de varacious.
POW
I’ve had mine for 2 or 3 months and probably could have used 2 or 3 stitches since then. It’s a very solid unicycle, although the crankset seems to have some play now. I still have to figure out a fix for that. One thing that makes the seat rock is the contours on the inside of the handle. Most unicycle handles including KH and Torker DX (as of 04 models) have a hollow grib, which isn’t as comfortable and can cause blisters. The Onza handle a thicker rounded inside giving it a much better grip.
But yeah, get pads or change the pedals.
