Yeah, I think maybe this is the place to go too. It seems really practical, a lot of people in the Unicycle Football League will hop out for this very reason. It’s a little bit frustrating because I ride with my seat very high…so I can barely bend my legs enough to jump even if I weren’t on a unicycle. That’s one reason I’ve put off working on it - I could easily double or triple (and with some effort, quadruple) what I imagine my maximum hopping height would be if I hopped with SIF, so it didn’t really seem a priority, as I’ve never ridden SIF before - until earlier today.
I tried to transition from riding to SIF, but simply couldn’t manage - my seat is so HIGH I couldn’t pull the back out in front of me…
So, I held onto a pole and started SIF against my body and had no problem making about 7 or 8 revolutions - called it a success and decided to save it for another day (I have to use most of my spare time on the 1fww, you know!)
Two notes on the 1fww, maximum 9 kicks, but they were controlled in a way that I did not reach yesterday at all. For instance, I had several situations when I was leaning too far to one side and I was able to ‘kick-correct’ or in layman’s terms, ‘turn’.
Also briefly practiced standing up for the SUWW without a support, which was surprisingly easy, though even with support, I cannot possibly imagine propelling myself from that position!
I’m pretty ambitious, but I know when I’ve met my match, and I think I’ve progressed as far as possible (excluding the ww and 1fww improvements to come) without going back to the basics.
So Reed, I will work on the SIF, if that’s the road to the Seat Drag, which is so awesomely impressive. Incidentally, this may involve hopping as a prerequisite, since I literally will probably have to hop in order to get the seat in front of me.
I want to make one more note on the wheelwalks. I saw a tutorial, (watched as many videos as I could find), and ONE and only one tutorial made a suggestion delivered peremptorily - it sounded more like a requirement! And that suggestion was…to adjust your seat to the maximum height you are comfortable with.
So there it is - a plausible explanation for why I have found this skill to be so easy to acquire while others often have not.
Also, it is really nice to have found this forum to be able to log my progress and get suggestions from helpful people such as yourselves, so thank you.
