I may have to use the idea sometime. May I suggest though, that you match the black of the original and the piece you added? Right now you can tell which is which.
Webmasters should avoid the use of the words “under construction” and associated images. That is, unless they’re fun images. But I don’t get why people post web content that isn’t content. Post it when it’s built! otherwise, assume we realize you will be adding more later.
But your image is a fun one, and you should just keep it somewhere else, if even on a perpetually “under construction” page!
It might be time for Sofa to look into getting a new monitor…
Or just turn up the brightness a bit (either hardware with a turning knob or a + button, or in software). Works wonders!
Klaas Bil
[no sig line for forum posts - still hoping that this is temporary]
