zippy
June 16, 2006, 7:47am
1
I was meant to get a coker same day as cathy but was a few days later, anyone it came and I’ve clocked up around 100 miles on it.
Must say, i noticed the toning I’m getting from unicycling
It’s a coker with:
Standard frame.
UDC hub.
stainless spokes.
airfoil.
coker tire.
nimbus gel seat.
nimbus Post clamp.
wellgo pedals.
I’ll save up for a decent frame at some point
And a decorative valve cap.
pdc
June 16, 2006, 7:53am
3
The stock frame will probably serve you indefinitely. No need to upgrade unless you are doing so for appearance or more rigidity when using a brake.
Awesome Coker! I dont see why you would need a nice frame? I mean as long as it doesnt break…
So you got all of those things separate so it was less expensive than buying one on Unicycle.com or did you just want a few special pieces…
So how much was it compared to the Coker on Unicycle.com … Just wanting an idea of what I need to spend… I am a little on the heavy side at 210lbs. so would this one hold strong???..
zippy
June 16, 2006, 8:23am
6
it’s the UDC coker with a upgrade.
could you take off the seat and put it right next to the seat clamp and measure down to the bottom pedal? I want to know If I’ll it on a coker.
edit: oh yea, congrats on the coker, It looks awesome!
that’s a beautiful two seated penny farthing you’ve got there!
