So, I did a nice big loop last night, suffering though the beginning heat and humidity of early summer, but I just had to get Hans on thr trails
Pre set up: KH 29, KH FR 47mm rim, Ardent 2.4 @ 16-18psi
Post set up: KH 29, KH FR 47mm rim, Hans Dampf @ 14-16psi
First off, I really like the Ardent 2.4, it has been a great tire for me, wet or dry, I have ridden this tire may miles over the past year + and my only complaint in that time is that the Ardent could use a slightly sturdier casing and sidewall, BUT taken a complete tire it is a very balanced design.
Last night my ride with Hans @ 16psi started with a 100yds of asphalt, so the first thing I looked at was crowning issues; the Hans does not crown hadly as much as the Ardent. So then I headed into some firm up/down flowing single track, I found the Hans to be a bit firmer than the Ardent, “fewer hard hits” as I went over roots and landing off smal drops was more secure/stable.
Then I headed into some technical, rocky ledges, steady climbing for 1/4 mile, Hans handled quite well, stuck to the rock at least as good as the Ardent, fewer hard hits as expected. The climbing felt good, the Hans seems to hold a line better than the Ardent and was easier to transition across rough terrain.
From there I headed into a technical downhill, mostly firm dirt and some root drops, a little firm mud, Hans did as well or better than the Ardent. I was getting zapped by the humidity at this point, so I missed a couple lines and had to go back and do them again, otherwise Hans was working well.
After a break I headed into a mixed single track section along the water, a little firm mud, lots of roots, some rock, Hans was feeling a bit too firm probably cuz I was getting tired, so I dropped the pressure to 14psi. Things were very different, tire was noticeabley slower and I struggled a bitto stay on my line, but I chalk some of that up to being fatigued. After a little bit I get back in the swing, my riding felt better and I was able to clean a series of “climbing” root stairs that usually gives me trouble. I also noticed that even at 14psi I was still not getting much in terms of hard hits, so the casing was very supportive even at low psi.
The last technical section is an easy downhill into a wood bridge leading to a rooty/rocky/eroded hill climb that I have never cleaned; came cloase last week on my 26er. Well, I cleaned it, smoothly and without much strain, suprising considering my fatigue. Was it the tire?
So, after one ride, Hans 1, Ardent 0, but with some caveats: The Hans rides firm, even at 14psi, so for light folks this might not be comfortable, though maybe at 12psi it would be fine. In terms of ride quality the Ardent is more comfortable and maybe faster, though I wouldn’t say that Hans is slow, because it’s not. Hans is a firmer casing and lands drops far better than the Ardent, more like a light DH tire such as my Arrow 26 x 2.6, so for folks whouse their 29er for tech muni, the Hans would be a better choice than the Ardent.
In conclusion, noting that I have only taken one ride; though it was a good test ride, I would say that the Ardent is a great tire for XC and light Freeride, but for Freeeride and light DH the Hans is a far better choice. Now the price, wow, $80 delivered is not cheap, but tires seem to last for a while…
My question now is whether a 26 x 2.4 Hans would be a nice 26er tire
